ONTAP EMS reference
nblade.nosmbvernegotiated events
nblade.nosmbvernegotiated EMS events occur when Data ONTAP® does not support any of the SMB protocol versions sent by the client for negotiation.
Nblade.noSmbVerNegotiated
Severity
ERROR
This message occurs when Data ONTAP® does not support any of the SMB protocol versions sent by the client for negotiation.
Corrective Action
Ensure that the client supports at least one of the enabled SMB versions. You can determine whether an SMB version is enabled by running the "vserver cifs options show" command in advanced mode.
Syslog Message
For Vserver "%s", Data ONTAP® could not negotiate with the client "%s" because it does not support any of the SMB protocol versions that the client sent in the list "%s".
vserverName (STRING): Vserver associated with this operation.
clientIp (STRING): IP address of the client attempting to negotiate.
clientVersionList (STRING): List of the SMB protocol versions sent by the client.
