sla.shelf events
Creating your file...
sla.shelf.mod.reboot
- Severity
NOTICE
- Description
This message occurs when a shelf firmware module is rebooted administratively, or when a reboot occurs normally when the system powers up, the firmware is updated, or the alternate control path (ACP) is reset.
- Corrective Action
(None).
- Syslog Message
Reboot event reported by module %s in shelf: %s, log: %s
- Parameters
module (STRING): Module designator (A or B).
shelf (STRING): Shelf identifier.
log (STRING): Reboot event log from the shelf module.
sla.shelf.mod.reboot.unexp
- Severity
ERROR
- Description
This message occurs when a shelf firmware module reboots unexpectedly (not due to powering up, a firmware update, an alternate control path (ACP) reset, nor an administrative reboot).
- Corrective Action
Check the cabling to the shelf. Check the status LED on the shelf, making sure that the fault LEDs are not on. Clear any fault condition, if possible.
- Syslog Message
Unexpected reboot event reported by module %s in shelf: %s, log: %s
- Parameters
