sla.shelf events
sla.shelf.mod.reboot
Severity
NOTICE
This message occurs when a shelf firmware module is rebooted administratively, or when a reboot occurs normally when the system powers up, the firmware is updated, or the alternate control path (ACP) is reset.
Corrective Action
(None).
Syslog Message
Reboot event reported by module %s in shelf: %s, log: %s
module (STRING): Module designator (A or B).
shelf (STRING): Shelf identifier.
log (STRING): Reboot event log from the shelf module.
sla.shelf.mod.reboot.unexp
Severity
ERROR
This message occurs when a shelf firmware module reboots unexpectedly (not due to powering up, a firmware update, an alternate control path (ACP) reset, nor an administrative reboot).
Corrective Action
Check the cabling to the shelf. Check the status LED on the shelf, making sure that the fault LEDs are not on. Clear any fault condition, if possible.
Syslog Message
Unexpected reboot event reported by module %s in shelf: %s, log: %s
