The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
telnet.threadcreate events
Creating your file...
Your file is ready
telnet.threadCreate.failure
- Severity
ERROR
- Description
This message occurs when creation of telnet daemon threads or telnet session threads fails because required virtual memory is unavailable. This happens when the system is overloaded.
- Corrective Action
Reduce the number of applications running on the storage system, then retry the operation.
- Syslog Message
Creation of %s thread failed.
- Parameters
threadName (STRING): Name of the thread that cannot be created.
