The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
mcc.network events
Creating your file...
Your file is ready
mcc.network.congestion
- Severity
NOTICE
- Description
This message occurs when a MetroCluster over IP configuration detects network congestion over the inter-cluster links (ISL) that connect sites and an action is taken to reduce further network congestion.
- Corrective Action
Verify that network between MetroCluster sites is following minimum SLA requirements and fix any such violations if needed. If the issue persists, contact NetApp technical support.
- Syslog Message
Network congestion detected. Action taken: %s.
- Parameters
action_taken (STRING): Action taken to reduce network congestion.
