The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
mgmt.rst events
Creating your file...
Your file is ready
mgmt.rst.fail.dst.compressed
- Severity
ERROR
- Description
This message occurs when the SnapMirror® 'restore' command fails because compression is enabled on the destination volume.
- Corrective Action
Force a cleanup of the failed operation by reissuing the 'restore' command with the parameter 'clean-up-failure', disable compression on the destination volume, create a Snapshot(tm) copy, and then reissue the 'restore' command.
- Syslog Message
SnapMirror restore from source volume '%s' to destination volume '%s' failed with error: %s.
- Parameters
srcpath (STRING): Path name of the source volume for restore.
dstpath (STRING): Path name of the destination volume for restore.
error (STRING): Error message.
