ONTAP EMS reference
dbs.disconn events
dbs.disconn EMS events occur when the Distributed Block Store detects that a remote node is not connected to the cluster network.
dbs.disconn.remote.node
Severity
ERROR
This message occurs when the Distributed Block Store (DBS) detects that a remote node is not connected to cluster network. The DBS is responsible for managing the data that backs the FlexVols®.
Corrective Action
Ping the remote nodes using jumbo frames to test network connectivity.
Syslog Message
The Distributed Block Store has detected that a remote node is not connected to cluster network. The cluster fault type is %s and fault id is %u.
cfType (STRING): DBS cluster fault type of the associated object.
cfID (INT): DBS cluster fault ID number associated with the fault.
cfStatus (INT): Current status of the cluster fault. 1 = New (just reported), 2 = Existing (updated), 3 = Resolved (closed).
cfDetails (STRING): Description of the cluster fault, including context details.
cfExtSrc (STRING): DBS cluster fault externalSource label created by the CreateClusterFault API command and attached to the fault for testing purposes.
