dbs.disconn events
dbs.disconn EMS events occur when ONTAP encounters issues associated with distributed block store cluster or node connectivity.
dbs.disconn.cluster.pair
- Severity
ERROR
- Description
This message occurs when the distributed block store detects that a cluster pair is disconnected or configured incorrectly. The distibuted block store is responsible for managing the data that backs the flexible volumes.
- Corrective Action
Check network connectivity between clusters. One of the clusters in the pair might have become misconfigured or disconnected. Remove the local pairing and retry pairing the clusters.
- Syslog Message
The distributed block store detects that the cluster pair is disconnected or configured incorrectly. The cluster fault type is %s and fault id is %u.
- Parameters
cfType (STRING): Distibuted block store cluster fault type of the associated object.
cfID (INT): Distibuted block store cluster fault ID number associated with the fault.
cfStatus (INT): Current status of the cluster fault. 1 = New (just reported), 2 = Existing (updated), 3 = Resolved (closed).
cfDetails (STRING): Description of the cluster fault, including context details.
cfExtSrc (STRING): Distibuted block store cluster fault external source label created by the "CreateClusterFault" API command and attached to the fault for testing purposes.
dbs.disconn.remote.node
- Severity
ERROR
- Description
This message occurs when the Distributed Block Store (DBS) detects that a remote node is not connected to cluster network. The DBS is responsible for managing the data that backs the FlexVols®.
- Corrective Action
Ping the remote nodes using jumbo frames to test network connectivity.
- Syslog Message
The Distributed Block Store has detected that a remote node is not connected to cluster network. The cluster fault type is %s and fault id is %u.
- Parameters
cfType (STRING): DBS cluster fault type of the associated object.
cfID (INT): DBS cluster fault ID number associated with the fault.
cfExtSrc (STRING): DBS cluster fault externalSource label created by the CreateClusterFault API command and attached to the fault for testing purposes.
