The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
tcp.change events
Creating your file...
Your file is ready
tcp.change.cc.algorithm
- Severity
ERROR
- Description
This message occurs when an attempt to change the TCP congestion control algorithm fails.
- Corrective Action
Check the node health, address any issues found, and then try the command again.
- Syslog Message
An error (out of memory) occurred while changing the TCP congestion control algorithm of existing connection(s) to %s. The NewReno (RFC6582) will be used as the congestion control algorithm for those connections.
- Parameters
cc_algo (STRING): Name of the congestion control algorithm to which the change was attempted.
