tcp.change events
tcp.change.cc.algorithm
- Severity
ERROR
- Description
This message occurs when an attempt to change the TCP congestion control algorithm fails.
- Corrective Action
Check the node health, address any issues found, and then try the command again.
- Syslog Message
An error (out of memory) occurred while changing the TCP congestion control algorithm of existing connection(s) to %s. The NewReno (RFC6582) will be used as the congestion control algorithm for those connections.
- Parameters
cc_algo (STRING): Name of the congestion control algorithm to which the change was attempted.
