The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
kern.version events
Creating your file...
Your file is ready
kern.version.change
- Severity
NOTICE
- Description
This message occurs when you reboot your system with a version of the Data ONTAP® kernel that is different from the one you ran previously.
- Corrective Action
(None).
- Syslog Message
Data ONTAP kernel version was changed from %s to %s.
- Parameters
oldver (STRING): Previous version of the Data ONTAP kernel.
newver (STRING): Current version of the Data ONTAP kernel.
