      adt.wrkrq events
adt.wrkrq.init.fail
- Severity
ALERT
 - Description
This message occurs when an internal audit worker queue fails to initialize.
 - Corrective Action
Available system resources are required for this feature to function. The Audit subsystem might not function, or might function with reduced performance. The best way to accomplish that is through a system reboot. For HA configurations, operational disruption can be minimized by initiating a partner takeover followed by a reboot of this partner. After the reboot is complete,issue a "giveback" command to return services to this partner.
 - Syslog Message
Audit subsystem internal error: Audit worker queue failed to initialize; system reboot might be required.
 - Parameters
(None).
