The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
token.node events
Creating your file...
Your file is ready
token.node.max.count.reached
- Severity
NOTICE
- Description
This message occurs when the maximum number of tokens per node is reached. Tokens cannot be created in the node unless some existing tokens expire.
- Corrective Action
(None).
- Syslog Message
Tokens cannot be created on this node because the maximum number of tokens per node has been reached.
- Parameters
(None).
token.node.out.of.quorum
- Severity
NOTICE
- Description
This message occurs when a node goes out of quorum. Any references on a token by that node will be dropped.
- Corrective Action
(None).
- Syslog Message
All token references from node (ID - %s) are dropped because the node went out of quorum.
- Parameters
blade_id (STRING): Blade ID of the node that went out of quorum.
