token.node events
token.node.max.count.reached
Severity
NOTICE
This message occurs when the maximum number of tokens per node is reached. Tokens cannot be created in the node unless some existing tokens expire.
Corrective Action
(None).
Syslog Message
Tokens cannot be created on this node because the maximum number of tokens per node has been reached.
(None).
token.node.out.of.quorum
Severity
NOTICE
This message occurs when a node goes out of quorum. Any references on a token by that node will be dropped.
Corrective Action
(None).
Syslog Message
All token references from node (ID - %s) are dropped because the node went out of quorum.
blade_id (STRING): Blade ID of the node that went out of quorum.
