token.node events
Creating your file...
Your file is ready
token.node.max.count.reached
- Severity
NOTICE
- Description
This message occurs when the maximum number of tokens per node is reached. Tokens cannot be created in the node unless some existing tokens expire.
- Corrective Action
(None).
- Syslog Message
Tokens cannot be created on this node because the maximum number of tokens per node has been reached.
- Parameters
(None).
token.node.out.of.quorum
- Severity
NOTICE
- Description
This message occurs when a node goes out of quorum. Any references on a token by that node will be dropped.
- Corrective Action
(None).
- Syslog Message
All token references from node (ID - %s) are dropped because the node went out of quorum.
- Parameters
blade_id (STRING): Blade ID of the node that went out of quorum.
