The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
nvmeof.onlyoneport events
Creating your file...
Your file is ready
nvmeof.onlyoneport.clear
- Severity
NOTICE
- Description
This message occurs when there is no longer only one port cabled from a node to a shelf.
- Corrective Action
(None).
- Syslog Message
There is no longer only one port cabled from node %s to shelf with SN %s.
- Parameters
node_name (STRING): Host name connected to the cable.
shelf_sn (STRING): Serial number of the shelf connected to the cable.
nvmeof.onlyoneport.error
- Severity
ERROR
- Description
This message occurs when host port is incorrectly cabled to a shelf.
- Corrective Action
The host port is incorrectly cabled to shelf. two ports must be connected to ensure redundancy.
- Syslog Message
There is only one port cabled from node %s to Shelf with SN %s.
- Parameters
