ONTAP EMS reference
nvmeof.onlyoneport events
nvmeof.onlyoneport EMS events occur when ONTAP encounters issues associated with single port connectivity to shelves.
nvmeof.onlyoneport.clear
Severity
NOTICE
This message occurs when there is no longer only one port cabled from a node to a shelf.
Corrective Action
(None).
Syslog Message
There is no longer only one port cabled from node %s to shelf with SN %s.
node_name (STRING): Host name connected to the cable.
shelf_sn (STRING): Serial number of the shelf connected to the cable.
nvmeof.onlyoneport.error
Severity
ERROR
This message occurs when host port is incorrectly cabled to a shelf.
Corrective Action
The host port is incorrectly cabled to shelf. two ports must be connected to ensure redundancy.
Syslog Message
There is only one port cabled from node %s to Shelf with SN %s.
