ONTAP EMS reference
vf.cleanup events
vf.cleanup EMS events occur when some subsystems are unable to cleanup properly when a local host vfiler is destroyed or when a partner vfiler is being shutdown during giveback.
vf.cleanup.error
Severity
ERROR
This event occurs when some subsystems are unable to cleanup properly when a local host vfiler is destroyed or when a partner vfiler is being shutdown during giveback.
Corrective Action
Log a support case with NetApp technical support. Try starting the vfiler, stopping and destroying it again.
Syslog Message
vfiler %s: %s subsystem could not cleanup properly.
vfName (STRING): The vfiler being shutdown or destroyed.
module (STRING): The module which could not cleanup vfiler specific information properly.
