The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
vf.cleanup events
Creating your file...
Your file is ready
vf.cleanup.error
- Severity
ERROR
- Description
This event occurs when some subsystems are unable to cleanup properly when a local host vfiler is destroyed or when a partner vfiler is being shutdown during giveback.
- Corrective Action
Log a support case with NetApp technical support. Try starting the vfiler, stopping and destroying it again.
- Syslog Message
vfiler %s: %s subsystem could not cleanup properly.
- Parameters
vfName (STRING): The vfiler being shutdown or destroyed.
module (STRING): The module which could not cleanup vfiler specific information properly.
