ONTAP EMS reference
extcache.unallowed events
extcache.unallowed EMS events occur when an external cache bootarg or setflag is set without the required privilege.
extCache.unallowed.option
Severity
NOTICE
This message occurs when an external cache bootarg or setflag is set without the required privilege. The default value is used instead.
Corrective Action
(None).
Syslog Message
WAFL external cache %s %s is set without the required privilege; using the default value.
type (STRING): Whether the option set is a bootarg or a setflag.
option (STRING): Option name.
