extcache.unallowed events
Creating your file...
Your file is ready
extCache.unallowed.option
- Severity
NOTICE
- Description
This message occurs when an external cache bootarg or setflag is set without the required privilege. The default value is used instead.
- Corrective Action
(None).
- Syslog Message
WAFL external cache %s %s is set without the required privilege; using the default value.
- Parameters
type (STRING): Whether the option set is a bootarg or a setflag.
option (STRING): Option name.
