The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
extcache.unallowed events
Creating your file...
Your file is ready
extCache.unallowed.option
- Severity
NOTICE
- Description
This message occurs when an external cache bootarg or setflag is set without the required privilege. The default value is used instead.
- Corrective Action
(None).
- Syslog Message
WAFL external cache %s %s is set without the required privilege; using the default value.
- Parameters
type (STRING): Whether the option set is a bootarg or a setflag.
option (STRING): Option name.
