monitor.globalstatus events
Creating your file...
monitor.globalStatus.critical
- Severity
EMERGENCY
- Description
This message occurs when the system's global health is critical; for example, if a fan failed.
- Corrective Action
Check the event log for other conditions that can cause this global status message. Follow the corrective actions in those messages.
- Syslog Message
%s
- Parameters
problem (STRING): System problem description.
monitor.globalStatus.nonCritical
- Severity
ERROR
- Description
This message occurs when the system's global health is degraded; for example, if a file system is nearly full.
- Corrective Action
- Syslog Message
%s
- Parameters
monitor.globalStatus.nonRecoverable
- Severity
EMERGENCY
- Description
This message occurs when the system's global health is non-recoverable, and the system is shutting down. There are currently no examples of this failure.
- Corrective Action
- Syslog Message
%s
- Parameters
monitor.globalStatus.ok
- Severity
NOTICE
- Description
This message occurs when the system's global health returns to normal.
- Corrective Action
(None).
- Syslog Message
%s
- Parameters
problem (STRING): Description of the system's normal condition.
