ONTAP EMS reference
monitor.globalstatus events
monitor.globalStatus.critical
Severity
EMERGENCY
This message occurs when the system's global health is critical; for example, if a fan failed.
Corrective Action
Check the event log for other conditions that can cause this global status message. Follow the corrective actions in those messages.
Syslog Message
%s
problem (STRING): System problem description.
monitor.globalStatus.nonCritical
Severity
ERROR
This message occurs when the system's global health is degraded; for example, if a file system is nearly full.
Corrective Action
Syslog Message
%s
monitor.globalStatus.nonRecoverable
Severity
EMERGENCY
This message occurs when the system's global health is non-recoverable, and the system is shutting down. There are currently no examples of this failure.
Corrective Action
Syslog Message
%s
monitor.globalStatus.ok
Severity
NOTICE
This message occurs when the system's global health returns to normal.
Corrective Action
(None).
Syslog Message
%s
problem (STRING): Description of the system's normal condition.
