ONTAP EMS reference
monitor.globalstatus events
monitor.globalstatus EMS events occur when ONTAP encounters issues associated with system global health status.
monitor.globalStatus.critical
Severity
EMERGENCY
This message occurs when the system's global health is critical; for example, if a fan failed.
Corrective Action
Check the event log for other conditions that can cause this global status message. Follow the corrective actions in those messages.
Syslog Message
%s
problem (STRING): System problem description.
monitor.globalStatus.nonCritical
Severity
ERROR
This message occurs when the system's global health is degraded; for example, if a file system is nearly full.
Corrective Action
Syslog Message
%s
monitor.globalStatus.nonRecoverable
Severity
EMERGENCY
This message occurs when the system's global health is non-recoverable, and the system is shutting down. There are currently no examples of this failure.
Corrective Action
Syslog Message
%s
monitor.globalStatus.ok
Severity
NOTICE
This message occurs when the system's global health returns to normal.
Corrective Action
(None).
Syslog Message
%s
problem (STRING): Description of the system's normal condition.
