The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
fg.modify events
Creating your file...
Your file is ready
fg.modify.workflow
- Severity
NOTICE
- Description
This message occurs when a user modifies the workflow type of a FlexGroup volume.
- Corrective Action
(None).
- Syslog Message
The workflow type for FlexGroup volume "%s" in Vserver "%s" was modified from "%s" to "%s".
- Parameters
volumeName (STRING): Name of the FlexGroup volume.
vserverName (STRING): Name of the Vserver on which the FlexGroup volume resides.
oldWorkflow (STRING): The old workflow type of the FlexGroup volume.
newWorkflow (STRING): The new workflow type for the FlexGroup volume.
