ONTAP EMS reference
snapvault.src events
snapvault.src EMS events occur when ONTAP encounters issues associated with the SnapVault® source service.
snapvault.src.notEnabled
Severity
ERROR
This message occurs when a SnapVault® source appliance receives a transfer request when the service is not enabled. The license needed depends on the transfer type. For SnapVault restore transfers, the appliance must have a secondary license. For other transfers, the appliance must have a primary license.
Corrective Action
Enable the service by issuing the command 'options snapvault.enable on'. You might need to license the service before you enable it.
Syslog Message
Command request (%d) from host %s while SnapVault is not enabled.
cmd (INT): Protocol command number for the type of transfer being requested.
dst_ip (STRING): IP address of the destination issuing the transfer request.
snapvault.src.volume.migrating
Severity
ERROR
This message occurs when a SnapVault® Snapshot(tm) target is initiated on a SnapVault primary volume while the volume is being migrated. The target might have been scheduled or manually invoked (through the 'snapvault snap create' command or programmatic interfaces).
Corrective Action
Wait for the volume migration to be completed.
Syslog Message
SnapVault primary volume %s is currently being migrated.
volname (STRING): Name of the SnapVault primary volume, on which the target is invoked.
