cf.rv events
cf.rv.connected
Severity
INFORMATIONAL
This message occurs when an HA connection agent connects on an HA interconnect device.
Corrective Action
(None).
Syslog Message
HA interconnect: Connection for '%s' succeeded.
rv_name (STRING): Logical name of the successful HA connection.
cf.rv.flush.handleExchange
Severity
INFORMATIONAL
This message occurs when HA interconnect exchanges flushing information with the partner.
Corrective Action
If the flush handle exchange reports "inactive", the remote controller might be running a version of Data ONTAP® that does not support flushing. Make sure that the controller and its partner are running compatible versions of the software.
Syslog Message
HA interconnect: Flushing is %s.
s (STRING): Flushing status.
cf.rv.localNoConn
Severity
INFORMATIONAL
This message occurs when the local controller votes not to connect to the HA partner. This can be caused by incompatibility between the software versions running on the two controllers.
Corrective Action
Install compatible versions of software on both controllers.
Syslog Message
HA interconnect: Local controller voted not to connect.
(None).
cf.rv.nicReset
Severity
ERROR
This message occurs when HA interconnects are reset due to NVRAM log being unsynchronized for longier time than 15seconds.
Corrective Action
Contact NetApp technical support if the problem persists.
Syslog Message
HA interconnect: Reset due to unsynchronized log.
(None).
cf.rv.notConnected
Severity
ALERT
This message occurs when an HA connection agent fails to connect on an HA interconnect device.
Corrective Action
Verify that both controllers in the HA pair are operational. If this message persists, disable and reenable the link by using the (privilege: advanced) "system ha interconnect link off" and "system ha interconnect link on" commands.
Syslog Message
HA interconnect: Connection for '%s' failed.
rv_name (STRING): Logical name of the failing HA connection.
cf.rv.partnerNoConn
Severity
ERROR
This message occurs when the HA partner votes not to connect to this controller. This can happen if the HA partner detects an incompatibility between the software versions running on the two controllers.
Corrective Action
Syslog Message
HA interconnect: Partner voted not to connect.
(None).
