ONTAP EMS reference
san.slmsupportcheckfailed events
san.slmSupportCheckFailed
Severity
ERROR
This message occurs during reboot when SAN capability is enabled, the cluster has more than 8 nodes and lun.reporting.nodes options is disabled. It leads to host instability as the number of paths exposed exceeds the threshold that the host stacks can handle.
Corrective Action
Set the option "lun.reporting_nodes.enable" to "on" with the command "vserver options lun.reporting_nodes.enable on" and enable Selective LUN Map on existing maps with the command "lun mapping add-reporting-nodes -vserver * -path * -igroup * -local-nodes".
Syslog Message
Clusters with more than 8 nodes must have SLM support enabled.
(None).
Looking for answers?
Try Doc, our Gen AI Assistant.
