ONTAP EMS reference
dev.path events
dev.path EMS events occur when the system fails to discover the drive.
dev.path.inquiry.failed
Severity
ERROR
This message occurs when the system fails to discover the drive.
Corrective Action
Use the "disk show -fields vmdisk-target-address" command to get the list of drives that are visible to the system and to verify that the missing drive is connected properly.
Syslog Message
Failed to discover drive (device name:%s%d).
periph_name (STRING): Drive name.
unit_no (INT): Drive unit number.
