dev.path events
Creating your file...
Your file is ready
dev.path.inquiry.failed
- Severity
ERROR
- Description
This message occurs when the system fails to discover the drive.
- Corrective Action
Use the "disk show -fields vmdisk-target-address" command to get the list of drives that are visible to the system and to verify that the missing drive is connected properly.
- Syslog Message
Failed to discover drive (device name:%s%d).
- Parameters
periph_name (STRING): Drive name.
unit_no (INT): Drive unit number.
