The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
scsiblade.mapped events
Creating your file...
Your file is ready
scsiblade.mapped.ns.attr.mod
- Severity
ERROR
- Description
This message occurs when a mapped NVMe namespace attribute changes as a result of a management operation. Changes in NVMe namespace attributes like size, state, or OS type, are not supported in this release.
- Corrective Action
Remove the namespace map using "vserver nvme subsystem map remove" command, then reapply it with the "vserver nvme subsystem map add" command.
- Syslog Message
The Namespace attributes of the Namespace with Vdisk ID '%s' in volume with MSID '%llu' in Vserver '%s' changed.
- Parameters
vdiskId (STRING): Vdisk ID of the LUN.
volume (LONGINTHEX): Volume identifier.
vserver (STRING): UUID of the Vserver that hosts the LUN.
