boot.varfs events
boot.varfs EMS events occur when ONTAP encounters issues associated with backing up or restoring the /var file system to the boot media or node root volume.
boot.varfs.backup.issue
- Severity
EMERGENCY
- Description
This message occurs when an error is detected while trying to back up the /var file system to the boot media or node root volume (mroot).
- Corrective Action
Contact NetApp technical support.
- Syslog Message
Backup of the /var file system failed (%s)
- Parameters
err_str (STRING): Error string.
boot.varfs.backup.success
- Severity
NOTICE
- Description
This message occurs when a subsequent backup is successful following a failure.
- Corrective Action
(None).
- Syslog Message
Backup of the /var file system is successful after previous failures.
- Parameters
(None).
boot.varfs.repair.partial
- Severity
ERROR
- Description
This message occurs when the system is unable to restore all missing files detected by a scan of the /var file system during boot.
- Corrective Action
- Syslog Message
Unable to restore all missing files in /var file system.
- Parameters
(None).
boot.varfs.repair.success
- Severity
NOTICE
- Description
This message occurs when missing files are restored during a scan of the /var file system during boot.
- Corrective Action
(None).
- Syslog Message
All missing files in /var are restored.
- Parameters
(None).
boot.varfs.restore.issue
- Severity
ALERT
- Description
This message occurs when an error is detected while restoring the /var file system from a shutdown.
- Corrective Action
The file system is automatically restored from the boot media. If the problem persists, contact NetApp technical support.
- Syslog Message
Failed to restore the /var file system. Error: %s
- Parameters
boot.varfs.restore.success
- Severity
NOTICE
- Description
This message occurs when, following a failure, a subsequent restore of the /var file system is successful.
- Corrective Action
(None).
- Syslog Message
Successfully restored the /var file system.
- Parameters
(None).
