ONTAP EMS reference
boot.varfs events
boot.varfs EMS events occur when ONTAP encounters issues associated with backing up or restoring the /var file system to the boot media or node root volume.
boot.varfs.backup.issue
Severity
EMERGENCY
This message occurs when an error is detected while trying to back up the /var file system to the boot media or node root volume (mroot).
Corrective Action
Contact NetApp technical support.
Syslog Message
Backup of the /var file system failed (%s)
err_str (STRING): Error string.
boot.varfs.backup.success
Severity
NOTICE
This message occurs when a subsequent backup is successful following a failure.
Corrective Action
(None).
Syslog Message
Backup of the /var file system is successful after previous failures.
(None).
boot.varfs.forced.umount.issue
Severity
ERROR
This message occurs when an I/O error is detected causing the /var file system to be forced umounted.
Corrective Action
The /var file system has been forced umounted due to I/O errors. Since /var is on the boot device, the forced umount of /var may cause errors on other components going forward. Please contact your hypervisor provider./>.
Syslog Message
I/O error caused forced umount of the /var file system.
boot.varfs.repair.partial
Severity
ERROR
This message occurs when the system is unable to restore all missing files detected by a scan of the /var file system during boot.
Corrective Action
Syslog Message
Unable to restore all missing files in /var file system.
(None).
boot.varfs.repair.success
Severity
NOTICE
This message occurs when missing files are restored during a scan of the /var file system during boot.
Corrective Action
(None).
Syslog Message
All missing files in /var are restored.
(None).
boot.varfs.restore.issue
Severity
ALERT
This message occurs when an error is detected while restoring the /var file system from a shutdown.
Corrective Action
The file system is automatically restored from the boot media. If the problem persists, contact NetApp technical support.
Syslog Message
Failed to restore the /var file system. Error: %s
boot.varfs.restore.success
Severity
NOTICE
This message occurs when, following a failure, a subsequent restore of the /var file system is successful.
Corrective Action
(None).
Syslog Message
Successfully restored the /var file system.
(None).
