snapvault.reg events
snapvault.reg.unknownOpt
- Severity
NOTICE
- Description
This message occurs when you downgrade from a kernel with newer version to one with an older version and the system attempts to read a registry entry that is supported only in the newer version of the kernel.
- Corrective Action
(None).
- Syslog Message
Unsupported registry entry: (%s).
- Parameters
regopt (STRING): Unrecognized registry entry for the older version of the kernel.
