ONTAP EMS reference
snapvault.reg events
snapvault.reg EMS events occur when you downgrade from a kernel with newer version to one with an older version and the system attempts to read a registry entry that is supported only in the newer version of the kernel.
snapvault.reg.unknownOpt
Severity
NOTICE
This message occurs when you downgrade from a kernel with newer version to one with an older version and the system attempts to read a registry entry that is supported only in the newer version of the kernel.
Corrective Action
(None).
Syslog Message
Unsupported registry entry: (%s).
regopt (STRING): Unrecognized registry entry for the older version of the kernel.
