      cpeer.receiver events
cpeer.receiver.noindex
- Severity
NOTICE
 - Description
This message occurs when an incoming cluster peer request using the system-generated passphrase. However, the cluster peer request failed because there is no matching outstanding cluster peer offers for the request in the system.
 - Corrective Action
Verify the peer request with peer cluster admin. If required, use the "cluster peer create" command with "generate-passphrase" option to generate the additional cluster peer offers.
 - Syslog Message
The cluster peer request from the remote cluster (%s) using the system-generated passphrase (Index: %d) has failed because cluster peer offer with system-generated passphrase is not available for this index.
 - Parameters
remote_cluster_details (STRING): Remote cluster name.
ppindex (INT): Cluster peer passphrase index.
