cpeer.receiver events
cpeer.receiver.noindex
Severity
NOTICE
This message occurs when an incoming cluster peer request using the system-generated passphrase. However, the cluster peer request failed because there is no matching outstanding cluster peer offers for the request in the system.
Corrective Action
Verify the peer request with peer cluster admin. If required, use the "cluster peer create" command with "generate-passphrase" option to generate the additional cluster peer offers.
Syslog Message
The cluster peer request from the remote cluster (%s) using the system-generated passphrase (Index: %d) has failed because cluster peer offer with system-generated passphrase is not available for this index.
remote_cluster_details (STRING): Remote cluster name.
ppindex (INT): Cluster peer passphrase index.
