sfu.downloadctrllerbridge events
sfu.downloadCtrllerBridge
- Severity
INFORMATIONAL
 - Description
This message occurs when a disk shelf firmware download starts on a particular disk shelf.
 - Corrective Action
(None).
 - Syslog Message
%s: Downloading %s on ES controller module %s via SES device %s.%d on %s.shelf%d.
 - Parameters
cmdName (STRING): Name of the command issued, such as "storage shelf firmware update".
fileName (STRING): Name of the file in /etc/shelf_fw that was being downloaded.
module (STRING): Either Module A or Module B, in which Module A is the upper module in the enclosure on the back side and Module B is the lower module in the enclosure on the back side.
channelNameSES (STRING): Name of the adapter port or switch port on the SES services device on which the disk shelf firmware download is occurring.
scsiId (INT): SCSI ID of the SES services device used to download disk shelf firmware.
channelNameShelf (STRING): Name of the adapter port or switch port on which the disk shelf firmware download is occurring.
shelfId (INT): ID of the disk disk shelf on which the disk shelf firmware download is occurring.
