sis.clog events
sis.clog.disabled
Severity
ERROR
This message occurs while mounting a volume, when an error with the SIS metafile operation results in the change logging function being disabled to avoid inconsistencies.
Corrective Action
Reinitialize the change logging operation by using the 'sis on' command.
Syslog Message
Change logging has been disabled for %s%s due to an error that occurred while mounting the volume during the SIS metafile operation: %s.
path (STRING): Path to the SIS volume.
volident (STRING): To uniquely identify the volume in cases where the volume name itself is insufficient.
reason (STRING): Reason for the failure.
