      sis.clog events
sis.clog.disabled
- Severity
ERROR
 - Description
This message occurs while mounting a volume, when an error with the SIS metafile operation results in the change logging function being disabled to avoid inconsistencies.
 - Corrective Action
Reinitialize the change logging operation by using the 'sis on' command.
 - Syslog Message
Change logging has been disabled for %s%s due to an error that occurred while mounting the volume during the SIS metafile operation: %s.
 - Parameters
path (STRING): Path to the SIS volume.
volident (STRING): To uniquely identify the volume in cases where the volume name itself is insufficient.
reason (STRING): Reason for the failure.
