sis.clog events
Creating your file...
Your file is ready
sis.clog.disabled
- Severity
ERROR
- Description
This message occurs while mounting a volume, when an error with the SIS metafile operation results in the change logging function being disabled to avoid inconsistencies.
- Corrective Action
Reinitialize the change logging operation by using the 'sis on' command.
- Syslog Message
Change logging has been disabled for %s%s due to an error that occurred while mounting the volume during the SIS metafile operation: %s.
- Parameters
path (STRING): Path to the SIS volume.
volident (STRING): To uniquely identify the volume in cases where the volume name itself is insufficient.
reason (STRING): Reason for the failure.
