ctl.ctlbe events
ctl.ctlbe.IOInternalError
Severity
ERROR
IO failure due to internal error
Corrective Action
The command failure associated with the device specified in this event is caused by some internal error.
Syslog Message
Device Serial Number %s - Internal error reason: %s - SCSI error : %s
devSerial (STRING): Device Serial Number
reason (STRING): Internal error
scsiError (STRING): SCSI error code
ctl.ctlbe.lunCreationFailed
Severity
ERROR
LUN creation failed in the CAM target layer.
Corrective Action
The creation of a CAM target end point for the LUN failed. This will cause the disk or partition to not be exported to the DR cluster, and therefore cannot be used for storage mirroring.
Syslog Message
LUN %d - endpoint creation failed, reason: %s
lunId (INT): The LUN ID
errorString (STRING): Description of the error
ctl.ctlbe.lunError
Severity
ERROR
The LUN has been deleted or is not configured properly
Corrective Action
The command failure associated with the device specified in this event is caused by the device being not configured or in error state. The device may be in the process of being deleted or the path to this device may not be accessible. Check the state of the device.
Syslog Message
Device Serial Number %s - Device is not configured or in error state - SCSI error : %s - LUN flags : 0x%x
lunFlags (INT): Internal CTL Backend LUN flags
ctl.ctlbe.lunNotConfigured
Severity
ERROR
The LUN is not configured
Corrective Action
The command failure associated with the device specified in this event is caused by the device not being configured. Check the state of the device.
Syslog Message
Device Serial Number %s - Device is not configured - SCSI error : %s
