ctl.ctlbe events
ctl.ctlbe EMS events occur when ONTAP encounters issues associated with CAM target layer operations.
ctl.ctlbe.IOInternalError
- Severity
ERROR
- Description
IO failure due to internal error
- Corrective Action
The command failure associated with the device specified in this event is caused by some internal error.
- Syslog Message
Device Serial Number %s - Internal error reason: %s - SCSI error : %s
- Parameters
devSerial (STRING): Device Serial Number
reason (STRING): Internal error
scsiError (STRING): SCSI error code
ctl.ctlbe.lunCreationFailed
- Severity
ERROR
- Description
LUN creation failed in the CAM target layer.
- Corrective Action
The creation of a CAM target end point for the LUN failed. This will cause the disk or partition to not be exported to the DR cluster, and therefore cannot be used for storage mirroring.
- Syslog Message
LUN %d - endpoint creation failed, reason: %s
- Parameters
lunId (INT): The LUN ID
errorString (STRING): Description of the error
ctl.ctlbe.lunError
- Severity
ERROR
- Description
The LUN has been deleted or is not configured properly
- Corrective Action
The command failure associated with the device specified in this event is caused by the device being not configured or in error state. The device may be in the process of being deleted or the path to this device may not be accessible. Check the state of the device.
- Syslog Message
Device Serial Number %s - Device is not configured or in error state - SCSI error : %s - LUN flags : 0x%x
- Parameters
lunFlags (INT): Internal CTL Backend LUN flags
ctl.ctlbe.lunNotConfigured
- Severity
ERROR
- Description
The LUN is not configured
- Corrective Action
The command failure associated with the device specified in this event is caused by the device not being configured. Check the state of the device.
- Syslog Message
Device Serial Number %s - Device is not configured - SCSI error : %s
- Parameters
