wafl.cbin events
wafl.cbin.iron.mirror.config.changed
Severity
INFORMATIONAL
This message occurs when cloud mirror configuration changes during the WAFLiron operation on a FabricPool aggregate with unified format enabled.
Corrective Action
Run wafliron again on the aggregate.
Syslog Message
The wafliron cannot update total physical size on bin label as cloud mirror configuartion has changed on aggreagate %s. Please run wafliron again on the aggregate.
aggregate_name (STRING): Aggregate name.
wafl.cbin.iron.objslothdr.invalid.entry.threshold.reached
Severity
INFORMATIONAL
This message occurs when number of invalid entries in objslothdr metafile reaches the upper threshold during the WAFLiron operation on a FabricPool aggregate with unified format enabled.
Corrective Action
Run the fixup tool on the Fabricpool aggregate and after the fixup tool finishes, run wafliron again on the aggregate.
Syslog Message
The wafliron cannot update total physical size on bin label as number of invalid entries in slothdr metafile reached the upper threshold on aggregate %s. Please run the fixup tool on the aggregate before running wafliron again.
wafl.cbin.label.total.physical.size.overcounted
Severity
INFORMATIONAL
This message occurs when overcounting of total physical size on the bin label happens due to invalid entries in slothdr metafile belonging to a Fabricpool aggregate with unified format enabled.
Corrective Action
Syslog Message
The total physical size on bin label belonging to Fabricpool aggregate %s might be overcounted as there were %llu invalid entries in slothdr metafile. The current physical used is %llu. Previously physical used was %llu. For further assistance, contact NetApp technical support.
invalid_entry_count (LONGINT): Number of invalid entries present in slothdr metafile.
physical_used (LONGINT): Current total physical used in capacity tier.
old_physical_used (LONGINT): Previous total physical used in capacity tier.
wafl.cbin.objslothdr.iron.skip.resync.in.progress
Severity
INFORMATIONAL
This message occurs when wafliron skips ironing objslothdr metafile on a FabricPool aggregate with unified format enabled as resync operation is in progress.
Corrective Action
Run wafliron again once resync operation is complete.
Syslog Message
Wafliron has skipped ironing objslothdr metafile on aggregate %s as resync operation is in progress on this aggregate. Please run wafliron after resync operation is complete.
