cf.mccip events
cf.mccip.med.auso.stDisabled
Severity
ERROR
This message occurs when automatic switchover in a MetroCluster(tm) IP configuration is disabled because the mediator mailbox disk is not healthy.
Corrective Action
Use the "storage failover show -fields local-mailbox-disks" command to verify that all nodes in the cluster can access their respective mailbox disks. Use the (privilege: advanced) "storage iscsi-initiator show" command to verify that iSCSI connections to the mediator are up and healthy.
Syslog Message
Automatic switchover disabled: Mediator mailbox disk not healthy.
(None).
cf.mccip.med.auso.stEnabled
Severity
NOTICE
This message occurs when automatic switchover in a MetroCluster(tm) IP configuration is enabled because the mediator mailbox disk is online.
Corrective Action
(None).
Syslog Message
Automatic switchover enabled.
(None).
