cf.mccip events
Creating your file...
Your file is ready
cf.mccip.med.auso.stDisabled
- Severity
ERROR
- Description
This message occurs when automatic switchover in a MetroCluster(tm) IP configuration is disabled because the mediator mailbox disk is not healthy.
- Corrective Action
Use the "storage failover show -fields local-mailbox-disks" command to verify that all nodes in the cluster can access their respective mailbox disks. Use the (privilege: advanced) "storage iscsi-initiator show" command to verify that iSCSI connections to the mediator are up and healthy.
- Syslog Message
Automatic switchover disabled: Mediator mailbox disk not healthy.
- Parameters
(None).
cf.mccip.med.auso.stEnabled
- Severity
NOTICE
- Description
This message occurs when automatic switchover in a MetroCluster(tm) IP configuration is enabled because the mediator mailbox disk is online.
- Corrective Action
(None).
- Syslog Message
Automatic switchover enabled.
- Parameters
(None).
