ONTAP EMS reference
cf.mccip events
cf.mccip EMS events occur when ONTAP encounters issues associated with automatic switchover in MetroCluster(tm) IP configurations.
cf.mccip.med.auso.stDisabled
Severity
ERROR
This message occurs when automatic switchover in a MetroCluster(tm) IP configuration is disabled because the mediator mailbox disk is not healthy.
Corrective Action
Use the "storage failover show -fields local-mailbox-disks" command to verify that all nodes in the cluster can access their respective mailbox disks. Use the (privilege: advanced) "storage iscsi-initiator show" command to verify that iSCSI connections to the mediator are up and healthy.
Syslog Message
Automatic switchover disabled: Mediator mailbox disk not healthy.
(None).
cf.mccip.med.auso.stEnabled
Severity
NOTICE
This message occurs when automatic switchover in a MetroCluster(tm) IP configuration is enabled because the mediator mailbox disk is online.
Corrective Action
(None).
Syslog Message
Automatic switchover enabled.
(None).
