clam.disable events
clam.disable
- Severity
INFORMATIONAL
 - Description
This message occurs when the Kernel Cluster Services (KCS) Connectivity, Liveliness, Availability Monitor (CLAM) is disabled by either turning off the KCS capability or by setting the 'clam sysctl/bootarg' variable.
 - Corrective Action
If you want CLAM functionality disabled, no action is needed. Otherwise, reenable CLAM and reboot the node to make CLAM operational again.
 - Syslog Message
CLAM functionality is disabled.
 - Parameters
(None).
clam.disable.takeover
- Severity
INFORMATIONAL
 - Description
This message occurs when the Kernel Cluster Services (KCS) Connectivity, Liveliness, Availability Monitor (CLAM) is disabled from initiating storage failover requests. This capability is automatically disabled in a NAS-only configuration. To control the setting of CLAM takeover, additional interfaces, such as sysctl bootarg, are provided.
 - Corrective Action
No action is needed.
 - Syslog Message
CLAM is disabled from performing storage failover.
 - Parameters
(None).
