The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
sfu.ctrllerelmntspershelf events
Creating your file...
Your file is ready
sfu.ctrllerElmntsPerShelf
- Severity
INFORMATIONAL
- Description
This message occurs when a disk shelf firmware download determines the number of controller elements per shelf that can be downloaded.
- Corrective Action
(None).
- Syslog Message
%s: %d ES controller %s can be updated on %s.shelf%d.
- Parameters
cmdName (STRING): Name of the command issued, such as "storage shelf firmware update".
count (INT): Number of ES controller elements on this shelf that can be downloaded.
pluralElement (STRING): Element or Elements.
channelName (STRING): Name of the adapter port or switch port on which the disk shelf firmware can be downloaded.
shelfId (INT): ID of the disk shelf on which the disk shelf firmware can be downloaded.
